Nayef Posted February 2, 2019 Posted February 2, 2019 (edited) hi after upgrade last version i have message : error when run Microsoft VBScript ... also some name channel arabic language wrong as : ?????? https://imgur.com/a/we2Ex6f support.zip Edited February 2, 2019 by Nayef Quote
Griga Posted March 10, 2019 Posted March 10, 2019 Try to fix it by removing the vbs files from C:\Program Files (x86)\DVBViewer\Scripts. Quote
Nayef Posted March 17, 2019 Author Posted March 17, 2019 The problem appears when I change the language of the system in Windows to Arabic, in previous versions there is no problem, this problem is also found in Media Server, where some characters appear as (???) Quote
Griga Posted March 19, 2019 Posted March 19, 2019 Am 17.3.2019 um 07:05 schrieb Nayef: The problem appears when I change the language of the system in Windows to Arabic, Did you change the language for your user account or for non-Unicode programs or both to Arabic? Please check the administrative tab of the regional settings. You can read more about it here. Parts of DVBViewer are still not Unicode-compatible, thus requiring to set up the language for non-Unicode programs correctly. Concerning the Media Server, it has to be considered that it is not running in your user account, but like most Windows services in a system account. The administrative tab of the regional settings allows to copy the user account settings to the system account. Quote
Nayef Posted March 21, 2019 Author Posted March 21, 2019 On 3/19/2019 at 10:12 AM, Griga said: Did you change the language for your user account or for non-Unicode programs or both to Arabic? Please check the administrative tab of the regional settings. You can read more about it here. Parts of DVBViewer are still not Unicode-compatible, thus requiring to set up the language for non-Unicode programs correctly. Concerning the Media Server, it has to be considered that it is not running in your user account, but like most Windows services in a system account. The administrative tab of the regional settings allows to copy the user account settings to the system account. The settings are correct but the problem still exists Before upgrading the last version I have no problem ... After upgrading to the latest version the problem appeared Quote
Griga Posted March 22, 2019 Posted March 22, 2019 Which version did you use before? I can't reproduce the problem. I did the following: Set the language for non-Unicode programs to Arabic (United Arab Emirates) -> reboot Set the language for my user account to Arabic (United Arab Emirates) Set the DVBViewer language to Arabic Relaunch DVBViewer I get no error whatsowever. I can't read Arabic, but the UI looks ok for me. However, I have no Arabic channel names in my list. Maybe your channel list (channels.dat) is required to reproduce the error. Quote
Nayef Posted March 23, 2019 Author Posted March 23, 2019 i try it but here result https://ibb.co/jfX1WCQhttps://ibb.co/F8mJ2sshttps://ibb.co/mN50dyxhttps://ibb.co/nP0qkrr Quote
Griga Posted March 23, 2019 Posted March 23, 2019 The screenshots don't tell me anything. I can't read it anyway. Probably your channels.dat will be necessary to reproduce the error. Quote
Nayef Posted March 24, 2019 Author Posted March 24, 2019 ya issue in " channels.dat " i try clean then scan new channel ... but issue return https://ufile.io/7xfa5 Quote
