jactkwn Posted February 16, 2019 Posted February 16, 2019 I have a link in aac format, it can be opened by pasting the link using “open url” function , but it cannot be opened when using channel list and dms. It could be opened before this afternoon until server stopped for a while. The link is https://playerservices.streamtheworld.com/api/livestream-redirect/CAPITAL958FMAAC.aac please advise, thanks! Quote
jactkwn Posted February 16, 2019 Author Posted February 16, 2019 Remark: I can open the link directly or on windows media player Quote
Griga Posted February 16, 2019 Posted February 16, 2019 The server responds very slowly. That's why this channel needs a longer connection timeout value. Goto Options -> Hardware, click Add -> TS Stream Device, then Settings (opens the TS Sream settings). Set the connection timeout to e.g. 10000 ms (this value makes it work here). Click OK in the settings dialog and again in the Options window. DVBViewer will not respond while it is waiting for the server reply. Quote
jactkwn Posted February 16, 2019 Author Posted February 16, 2019 37 minutes ago, Griga said: The server responds very slowly. That's why this channel needs a longer connection timeout value. Goto Options -> Hardware, click Add -> TS Stream Device, then Settings (opens the TS Sream settings). Set the connection timeout to e.g. 10000 ms (this value makes it work here). Click OK in the settings dialog and again in the Options window. DVBViewer will not respond while it is waiting for the server reply. Thanks. But what strange is other links by the same providers are working. Quote
jactkwn Posted February 17, 2019 Author Posted February 17, 2019 Thanks, it works! and can I do something on the configuration of TS stream device to solve my YouTube recording problem? Jacky Quote
