jaddi01 Posted March 25, 2019 Posted March 25, 2019 (edited) As the title says... I import complete EPG data with Xepg, which work fine and I get a full EPG. Then, close and reopen DVBViewer and all of the EPG data (bar a few channels) is gone. 100% repeatable everytime. DVBViewer has been reinstalled...no change. EPG.dat, deleted - no change EPG.dat is large, (36MB) therefore DATA is contained. Latest DVBViewer V6.1.4.0 and Xepg 0.7.2.0 I am importing a mixed language EPG comprising of Astra 19.2E German and 28.2E English. Edited March 25, 2019 by jaddi01 Spelling Quote
Delphi Posted March 27, 2019 Posted March 27, 2019 Are you using DVBViewer Media Server? If not, then make sure DVBViewer > Settings > Options > DVBViewer Media Server > "Enable support for the DVBViewer Media Server" is unchecked. If you are using it make sure that Xepg > Options > General > Import XMLTV EPG Into > "DVBViewer Media Server " is selected. Quote
jaddi01 Posted March 28, 2019 Author Posted March 28, 2019 Hi Delphi correct, I'm not using the media server. I`ve removed the tick, and.... it seems to be working! Many thanks! Quote
