RTP streams
mezzy
Hi. my internet provider has RTP video streams for live tv channels but it seems DVBViewer 6.1.3 can't play.
this files will be much appreciated to be added in future update
thanks in advance
Maybe you need to adjust your firewall settings:
Am 13.1.2019 um 19:09 schrieb hackbart:
Added: IPTV: Batch file DVBViewer_IPTV_Firewall_Rules.bat for setting up firewall rules that allow to receive (multicast) UDP IPTV originating from outside the home network, e.g. T-Entertain/Magenta TV. Please note: The file must be executed with administrator rights (right-click it → Run as administrator). Only use this file if DVBViewer is running behind a router. The file DVBViewer_Firewall_Rules.bat can be used to return to the normal (default) firewall setup.
It is available since DVBViewer 6.1.3.
thanks griga i will try like this - my stream is as rtp://@233.136.0.1:7500
Edited by mezzy
