spudjg1 Posted May 5, 2019 Posted May 5, 2019 (edited) Hi i was wondering if there is away to host my playlist on my media server to other clients on LAN using kodi i would like to view them via the video directory so i use the metadata option on the client? i have manged to set them all up using live TV DVBViewer add-on and it all works great . i cant seam to work out how to host the playlist . all the clients are running windows 10 Can any one help ? Edited May 5, 2019 by spudjg1 Quote
Griga Posted May 5, 2019 Posted May 5, 2019 The DVBViewer Media Server provides M3U playlists containing video or audio files (not URLs!) via UPnP if they are located in one of the media library directories. They also appear on the media page of the web interface. Here it shows the content of the file playlist.m3u that is located in one of my music directories. So if you configure Kodi as UPnP client it should be possible to access the playlist content. Quote
spudjg1 Posted May 6, 2019 Author Posted May 6, 2019 Thanks for the quick reply. Ok, i think i understand, this will only work with example mp4 file ect. my playlist only contains urls (m3u file vod provided from iptv service). is there away i can host m3u playlist files to clients via LAN, or do i need to manually set up my m3u playlist on each client device? Quote
Griga Posted May 6, 2019 Posted May 6, 2019 You can use the DMS API to provide an URL for playlist download if it is located in the DVBViewer/DMS configuration folder: http://www.dvbviewer.com/griga/changelog_dms_api.html#__RefHeading__25978_1410462625 Zitat Added: API: Download of files from the configuration folder and its sub-folders by using the following URL scheme: /api/getconfigfile.html?file=[path relative to the configuration folder]. Example: /api/getconfigfile.html?file=config%5Cservice.xml (with %5C as URL encoded backslash). Please note that files containing the sub-string “userdata” in their name are purposely excluded and can not be downloaded. If there is a file myplaylist.m3u in your configuration folder, you can download it from the web server by using http://[Media Server IP]:[Web Server Port]/api/getconfigfile.html?file=myplaylist.m3u Provided your web server port is still the default 8089, you can download the file in your browser on the server PC by using http://127.001:8089/api/getconfigfile.html?file=myplaylist.m3u Quote
spudjg1 Posted May 6, 2019 Author Posted May 6, 2019 (edited) 2 hours ago, Griga said: You can use the DMS API to provide an URL for playlist download if it is located in the DVBViewer/DMS configuration folder: http://www.DVBViewer.com/griga/changelog_dms_api.html#__RefHeading__25978_1410462625 If there is a file myplaylist.m3u in your configuration folder, you can download it from the web server by using http://[Media Server IP]:[Web Server Port]/api/getconfigfile.html?file=myplaylist.m3u Provided your web server port is still the default 8089, you can download the file in your browser on the server PC by using http://127.001:8089/api/getconfigfile.html?file=myplaylist.m3u Ok, my server port is set as default 8089. Im getting a little confused, are you a able to provide me with a step by step instructions to set my playlist up to host on my media server? Edited May 6, 2019 by spudjg1 Quote
