Multiple Istances (viewing windows) with multiple tuners
Riodda
Hi, it might be a silly question but i can't find the solution myself.
I have DVBviwer pro with 2 USB DVB-T tuners and i would like to have 2 windows of DVBViewer one per each tuner to view 2 channels at time.
What is the best way to archive this without using the media server ?
Thanks.
The next DVBViewer release will allow to optionally display "Picture in Picture" in a separate (independent) video window that can be moved to any screen position and be switched to full screen mode. So if you own two monitors, you can have two times full screen.
So by now the only option i have is to use Media Server and 2 vlc clients for example ?
You can have DVBViewer and DVBViewer GE running at the same time. I use the Media Server to do this, but I presume that you could get each program to look at a different tuner. There have been people installing two instances of DVBViewer on a PC wih different install folders, but I have never done it myself.
Edited by Cian
