zoom settings
bobo2211
i want the zoom settings to be easilly saved, without this feature i must set zoom setting every times i run the DVBViewer :bounce:;)
danke
The zoom settings are always stored, maybe your setup.ini is write protected.
Bye, Oliver
i mean the pan & scan zoom settings in Menu Settings -> Zooms, not the 50%, 100% or 200% in the other zoom settings ;)
hope this feature will be added
  • 1 month later...
is this feature will be added in next version of DVBViewer ?
Guest Oliver
It's already in the GE, so it will be implemented in the Pro version, too.
Bye
