How to stop DVBViewer to creating information files?
Sean99
Hi, can anybody help me? I use DVBViewer  Pro 4.2.1 for recording from satellite. It records very well but create information files for each files with the same name, how can I disable it and prevent to create text files? I disabled Create information file in Recordings tab but it didn’t help.
I appreciate any help in advance.
How to disable creating information files?
vor 1 Stunde schrieb Sean99:
DVBViewer  Pro 4.2.1
This is really an ancient version, used by my grandfather when he was young, if I remember it correctly... :) Nowadays hardly anybody knows how it worked. Look for an Options -> Recordings -> EPG Information File setting (or something similar). Good luck!
Thanks for answer. Yes it is old version but it works well.? I have already found that option and I disabled it but didn’t help. I will attach an image. It might remember something from ancient age.?
