jampeer Posted September 15, 2019 Posted September 15, 2019 Hey. Tell me why I get this error when analyzing and scanning the scan. How to fix it? Everything worked fine before. Quote
Griga Posted September 15, 2019 Posted September 15, 2019 How can I know if you don't tell me what you did? If you give no information, you will get no information. BTW: Please don't use topics that have been started by other members for posting your stuff off-topic!!! Rather start your own topic. Quote
jampeer Posted September 15, 2019 Author Posted September 15, 2019 (edited) Sorry, I'm using a translator. It's a little difficult to navigate. It started after replacing the motherboard and processor. Windows was not perseinstalled. It was just necessary to re-specify the dvb card (device) in the settings of the dvb viever and everything worked except the scanner. Channels work but I can’t scan a single frequency. Edited September 15, 2019 by Griga Made the posting readable without scrolling Quote
Griga Posted September 15, 2019 Posted September 15, 2019 Did you perform Settings -> Hardware -> Detect Devices in TransEdit? Please attach the file TransEdit.ini here. See Info -> Configuration Folder in TransEdit. 1 Quote
jampeer Posted September 15, 2019 Author Posted September 15, 2019 Thank you The reason was precisely that. Quote
