How to Create a new plugin?
mohammad izadpanah
Hi dears
Can anyone explain how to create new plugin for dvbdream or DVBViewer in multi steps like this?
step 1: user must use which language( like C or C# or visual c#)?
step 2: user writes codes in which software?
step 3: How the user learn and use functions of dvb softwares? (like which function get user freq info).
step 4: How the user create a dll for using in dvb softwares?
thanks a lot
You should first know what kind of plugin you want to create. If you need a low level you should download the sdk from the members section. The OSD Plugin System uses the COM Interface. You can easily get the required information by importing the DVBViewer COM Object.
It does not matter if you use C++/C# for the last one. C would be complicated if you want to use COM.
A good start for it is to have a look in the developer section of this forum.
Christian
  • Thanks 1
Quote
 I want to learn to write  plugin for dvb player. my first plugin shows some info of current channel like pids, bitrate, frequency, polarization, sat position and ....
is it possible to use VB.NET?
Any Software! Any recommendation?
like general methods to create dll.
Edited by mohammad izadpanah
is it possible to share source of a simple plugin? is it exist in forum?
I found several source of plugins in developer section but i didn't find sdk. Please send download link. Also please give me  members section link
  • 4 months later...
Hi friends
how can i get channel info according to attached file. I write a plugin in delphi 7 that show all channel info. Please write some codes.
unit main;
interface
uses
  Windows, Messages, SysUtils,StrUtils, Variants, Classes, Graphics, Controls, Forms,
  Dialogs, ComCtrls, TeEngine, Series, ExtCtrls, TeeProcs, Chart, Grids,about, ModuleAPI;
type
  Tfmain = class(TForm)
    Label1: TLabel;
    Label2: TLabel;
    Label2: TLabel;
procedure Tfmain.FormShow(Sender: TObject);
var
  tpinfo: TTuner;
begin
        Label11.Caption := inttostr(tpinfo.OrbitalPos);/////////// it is very important for me////////////////
        Label12.Caption := inttostr(tpinfo.Frequency);
        Label13.Caption := inttostr(tpinfo.SymbolRate);
end;
these codes doesn't work correct.why?
thanks
APIModule.zip
Use the following up-to-date TTuner declaration:
Spoiler
  TTuner = record
    TunerType: TTunerType;
    Group: TChannelGroup;
    Unused1: Byte;
    Flags: Byte;
    Frequency: DWord;
    SymbolRate: DWord; //or URL Hash 0..31
    LOF: Word; //LNB LOF, or TS Stream URL Hash 32..47
    PMT: Word;
    Volume: Byte;
    DiSEqCValueExt: Byte;
    SatModulation: Byte;
    AVFormat: Byte;
    FEC: Byte;
    AudioChannel: Byte;
    Unused3: Word; //SubtitlePID: Word; //TransEdit internal
    Polarity: Byte; //or Modulation or BandWidth
    Unused4: Byte; //Favourite: Byte; //DVBViewer GE internal
    OrbitalPos: Word;
    Tone: Byte; //22 khz off/on, or TS Stream stream type (only during runntime, not in channels.dat)
    EPGFlag: Byte;
    DiSEqCValue: Word; // OrbitPos, or other value: Positoner, GotoAngular, Command String, or TS Stream URL Hash 48..63
    DiSEqC: Byte; //None,SimpleA, SimpleB, PosA/OptA, PosB/OptA, PosA/OptB, PosB/OptB
    Language: TTunerLanguage;
    AudioPID: Word;
    Substream: Word; //changed for MPLP, replaces former NetworkNr: Byte; Favourite: Byte;
    VideoPID: Word;
    TransportStreamID: Word;
    TelePID: Word;
    NetworkID: Word;
    SID: Word;
    PCRPID: Word;
  end;
  • Thanks 1
thanks for new update but plugin shows zero for these variables. (OrbitalPos, frequency and SymbolRate).
Please read my codes again. is it correct?
var
  tpinfo: TTuner;
begin
end;
1- what is this ? is it necessary to use EventMsg  ?  how to use ?  Please write some codes.
EventMsg (evRemoveChannel, @Tuner) ;// with evRemoveChannel = 998: Is sent if a station is already being played and passes a pointer to its tuner data record
2- Like  TTuner declaration, what's declaration for channel info like name, provider, ecm, emm , ...?
According to this post by @Lars_MQ and up-to-date TTuner declaration by @Griga , Please help me to get transponder info (OrbitalPos, frequency and SymbolRate).
I am guessing that it's needed to  use  DVBViewer Plugin API Commands by SendMessage Functions.
1- is there any API COMMAND LIKE following COMMANDs to get TTuner records?
const
  WM_DVBVIEWER         = $B2C2;
  MSG_STARTPIDCALLBACK = $45104;
  MSG_STOPPIDCALLBACK  = $45105;
2- I found this in "DVBViewer SDK.chm" file. How can I use this to get Transponder info?
res:=SendMessage(dvbHandle,$B2C2,$1031,0); // returns the ServiceID<<16+Transponder
ecm and emm are not processed and stored in DVBViewer. Plugins must retrieve them from the DVB streams.
You can get the number and name of the currently played channel in the follwoing way:
type
  TSetChannel = packed record
    Channel: Integer; //channel number
    ChannelName: PAnsiChar;
  end;
  PSetChannel = ^TSetChannel;
var
  SC: TSetChannel
SendMessage(dvbHandle,WM_DVBVIEWER,MSG_GETCHANNEL,LPARAM(@SC));
but AFAIK there is no way to get the provider name.
Attached the source code of a little plugin that I wrote for correcting wrong bits in video/audio/teletext PES headers, in order to make a channel playable in DVBViewer. The function EventMsg shows how to get the tuner record.
PatchMarkerBits_Source.zip
  • Thanks 1
thanks a lot.
Please add a Simple Form to project to show freq info in Labels.(CurrentTuner.Frequency , CurrentTuner.SymbolRate , CurrentTuner.OrbitalPos)
Label1.Caption := 'Frequency = ' + IntToStr(CurrentTuner.Frequency) ;
Label2.Caption := 'SymbolRate = ' +IntToStr(CurrentTuner.SymbolRate ) ;
Label3.Caption :='OrbitalPos= ' + IntToStr(CurrentTuner.OrbitalPos) ;
Also add following procedure to project to show plugin in menu.
procedure SetMenuHandle(Menu: HMenu); stdcall;
begin
	//Please Write a some codes for me to learn
end;
procedure MenuItemClick(MenuID: integer); stdcall;
begin
end;
I'm ashamed to take your time! ?
