Filename when downloading DVBViewer
satdown
The filename when downloading DVBViewer is always DVBViewer_setup.exe, it would make much more sense if the version number was added to the filename e.g. DVBViewer_setup_6_1_4.exe, this would make it much easier to re-install an old version, or a particular version especially if you have problems.
AFAIK the setup files are automatically stored with the version number as part of their filename in C:\Program Files (x86)\DVBViewer\setup. Check it out...
