SVCdatabase.db3 update
mezzy
I noticed a problem in updating the list of records. As if there was a problem with svcdatabase created.
initial version DMS 2.1.4.
I wanted to update my list after adding the mediaserver version 2.1.6.x
and the recordings list is empty in kodi addon
the return to version 2.1.4 does not seem to suffer from problems and the list in kodi addon reappears correctly
Was it also empty in the DMS Web Interface?
That means, the recording database is ok and usable. I'll try to reproduce it. Which Kodi version are you using? Are the following steps correct?
  1. Update to DVBViewer 6.1.6.1
  2. Perform Web Interface -> Tasks -> Update Recording Database
  3. Check the list of recordings in Kodi.
