Retrofan Posted June 21, 2020 Posted June 21, 2020 (edited) Hi, I have some internet radio streams which doesn't work with DVBViewer Pro but do work with VLC. Can you fix this please? I don't hear audio. Maybe something is missing? For example: http://playerservices.streamtheworld.com/api/livestream-redirect/RADIO538.mp3 Thanks! Edited June 21, 2020 by Retrofan Quote
Griga Posted June 21, 2020 Posted June 21, 2020 vor einer Stunde schrieb Retrofan: For example: http://playerservices.streamtheworld.com/api/livestream-redirect/RADIO538.mp3 Here it works with the latest DVBViewer Pro version (Fix version from the members download area, beta section). If you can't make it work, reproduce the problem in DVBViewer Debug mode (see Windows start menu -> DVBViewer). After closing DVBViewer again, the file DVBViewer.log in the configuration folder will probably indicate what's wrong. Quote
Retrofan Posted June 21, 2020 Author Posted June 21, 2020 Hi, that's great, thanks! I will try the beta! Quote
Retrofan Posted June 23, 2020 Author Posted June 23, 2020 Still no luck. Here's the log file of the debug mode. What's wrong? support.zip Quote
Griga Posted June 23, 2020 Posted June 23, 2020 Most likely the audio decoder. Install the LAV Filters, if not yet done. Use the installer. Don't change the default settings. Then select the LAV Audio Decoder for MP3 on Settings -> DirectShow -> Audio. Quote
Retrofan Posted June 23, 2020 Author Posted June 23, 2020 (edited) OK, thanks, that did the trick. Stange it didn't work with the already installed decoders, as other streams did work perfectly from Enigma2 receiver. Anyway, it works! ? Edited June 23, 2020 by Retrofan Quote
