Upgrade Needed?
WGMaker
I purchased DVBViewer and the Mediaserver some time ago, maybe 1 year or more.
I haven’t used it because I was using an alternative solution .
Now I have downloaded it again applied the keyfile I still kept and entered the username and password for Viewer and Server.
I have some problems though, it looks as if the software remains in some kind of ‘debug mode’ and also the server is stopped and cannot be started again.
Question do I need to ‘upgrade’ because my license doesn’t cover the new versions?
Or is there another reason for my problem?
vor 22 Minuten schrieb WGMaker:
No.
Most likely yes. However, your description is not significant enough for providing help. Please describe the problem in more detail and attach a support.zip.
