il diavolo epm Posted July 29, 2020 Posted July 29, 2020 HbbTv Czech Television F5 does not work Quote
HaraldL Posted July 29, 2020 Posted July 29, 2020 Perhaps this? https://www.DVBViewer.tv/forum/topic/63769-hbbtv-is-signaled-but-is-not-displayed/ A fix for this is available in the beta section of the members area. Quote
il diavolo epm Posted August 3, 2020 Author Posted August 3, 2020 Thank you for answer, I tried but I still can't, I read something about debug mode and support.zip But I don't know how to do it. Quote
il diavolo epm Posted August 3, 2020 Author Posted August 3, 2020 I'm sorry to try again, I forgot to read ReadMe and the whole thread. Thank you for now Quote
il diavolo epm Posted August 5, 2020 Author Posted August 5, 2020 Please help DVBViewer_Fix_6_1_6_12 replace files ⦁ Close DVBViewer. ⦁ Go to your DVBViewer program directory (usually C:\Program Files (x86)\DVBViewer) ⦁ To be on the safe side, create a backup of the files that shall be replaced. ⦁ Replace files by the new versions that are contained in this ZIP file. ⦁ Restart DVBViewer There are fewer steps to replace and there are fewer of them I also need it because I have a TBS card and I can't scan DVB-T channels ? The Fix folder contains files other than DVBViwer ?? Quote
