joewil Posted February 4, 2005 Posted February 4, 2005 I want to scan for new channels on SStar2 which is connected by LNB out on my sat. receiver to my PC. in the online manuel i have printed out it states : Enter the values for the used LNB and the frequency of the area you would like to scan. Where would I find this information and what is the values for the used LNB? Many thanks to you all out there Quote
Derrick Posted February 4, 2005 Posted February 4, 2005 ..the most common type is the universal lnb. For the low band (<11700MHz) the lof has to be set to 9750MHz and for the high (>11700) band 10600MHz. The switching to the high band is done by the 22KHz signal. To scan the frequency bands, you'll need a transponder.ini for the corresponding satellite. The files that comes with a fresh installation of the DVBViewer-pro are sometimes outdated ..just ask for a recent file Quote
joewil Posted February 5, 2005 Author Posted February 5, 2005 Thanks for the info Derrick I will give it a try. Joe Quote
