Buying recommendation
Roland Markus
Hi!
I am from Austria and my 2nd DVBSky S960C USB Receiver died yesterday after about 2 years. (bought it on amazon)
I am searching for a cheap, good and more reliable replacement for this USB box.
The new box needs to have:
- a CI slot for ORF (CAM and card available)
- should also be connected by USB
- DVB-S2 (SD, HD, 4K with DVBViewer, which i bought)
I found this one:
https://www.tbs-technology.de/shop/DVB-S2-S-S2X-T-T2-C-C2-Single-Tuner-mit-CI-USB-Multituner-Empfangsbox-TBS-5580
Has anyone experience if the TBS-5580 is more reliable? Any better alternatives?
br
Roland
Edited by Roland Markus
I bet you get better responses regarding you setup with ORF in the german support forum.
