Channels update not successful
jkeskir
Preconditions: Channells.dat and channels.bak present
1. update channells
2. save updated channels
3. new channells are visible in DVBViewer
4. close  DVBViewer
5. open DVBViewer
6. new channels are not found
7. channells.dat and  channels.bak timestamp has not changed
8. rename channles.bak  channels.bak1
9. update channells
10 after restart of dvbviwer new channells are visible and channells.dat and channells.bak  timestamp has changed.
There have been no changes concerning reading/writing the channel list since 6.1.7.0. Can you still reproduce the issue? I can't with 6.1.7.1, and no one else has reported it, so don't think that there is something that has to be fixed. Maybe caused by access rights or write protection?
Tested now and channel saving works fine. Maybe it was something in my PC even after restart.  I was trying saving as normal user and also as admin. Strange indeed. Thanks and sorry to make do you extra work.
