Web Interface Access Right
ming.1210
This is the web interface accessed from localhost:
This is the web interface accessed from another computer in the same private network:
May I ask if any settings are required to allow changes (e.g. set up new timer) from a computer within the same private network? Now I need to remote access to the computer hosting the DMS just to set a timer.
Thank you for your help :)
Most likely you are using the restricted Media Server Basic version. It only allows access with guest rights from remote PCs. For full access rights you need to buy and install the full version.
