Quad HD cards
mradu
Hello.Except the Hauppauge Wintv-Quadhd(which is only HD ready) and TBS 6205(which has issues with encryption/freezing) there are other quad core cards on the market that are fully compatible with DVBViewer and are HD + DVB-C + CI(for encrypted channels) ? Thanks
You may want to check out Digital Devices cards. Quite expensive, but good quality and support. There is a close cooperation between this company and dvbviewer.tv. The cards are based on a modular system. You can start with a DVB-C/T dual tuner and expand it with additional tuners and CI modules.
