Qosmio Posted September 28, 2020 Posted September 28, 2020 After upgrade to DVBViewer Media server V2.1.7.0 Send mail when recording are finished and send mail when auto search adds new timers does not work anymore, testing send email works. Anybody has same problem? Cheers Quote
Griga Posted September 29, 2020 Posted September 29, 2020 Did you install DVBViewer Media Server Basic? On 7/22/2019 at 10:19 AM, hackbart said: DMS Basic cannot send an e-mail notification after a recording is finished. Quote
Qosmio Posted September 29, 2020 Author Posted September 29, 2020 Good question, i did not even know there was a version like that :), just downloaded the 2.1.7.1 version and installed it will post update if it's solved with the updated full version. Quote
Qosmio Posted October 1, 2020 Author Posted October 1, 2020 After the upgrade to 2.1.7.1 full version the issue is still there no email after finished recording or adding auto search, only the test send email works. Quote
Griga Posted October 1, 2020 Posted October 1, 2020 Confirmed and fixed. The Media Server Options (svcoptions.exe) don't write new mail settings to the file svcuserdata.xml. That's why it doesn't work. I could not reproduce it because my svcuserdata.xml already contained the settings. Please check your PMs... Quote
Qosmio Posted October 1, 2020 Author Posted October 1, 2020 Replaced the files but the issue is still there, on sending mail after recording and after creating timers, email config is all there in svcuserdata.xml, sending test email works. Quote
Griga Posted October 1, 2020 Posted October 1, 2020 Here it works. However, I noticed that entering email data and finishing with OK does not trigger a Media Server restart, which is necessary to let it read the changes. So I did it manually by stopping and restarting it via the tray menu. Please try if this helps... Quote
Griga Posted October 2, 2020 Posted October 2, 2020 P.S. Another possible reason for failure: The mail is sent, but classified as spam by the provider of the target mail address. Just happened here Quote
Qosmio Posted October 2, 2020 Author Posted October 2, 2020 Stopping and starting the service did not resolve the issue also reconfiguring the email configuration did not solve it, i have my own exchange mail server and mail from recording service is send on local lan to the exchange server and its not classified as spam (logs) and the test email is dropped in my inbox just fine. I like to reinstall the recording service but then i will lose all my recording inputs in the recording list or do you have a solution for that? Quote
Griga Posted October 2, 2020 Posted October 2, 2020 52 minutes ago, Qosmio said: I like to reinstall the recording service but then i will lose all my recording inputs in the recording list It won't happen unless you uninstall ithe Media Server first and let the uninstaller delete your settings. However, if you actually install the old Recording Service instead of the Media Server, I don't know... create a backup of your svctimers.xml first. In the meantime I've successfully run several tests. Have a look into the file svcdebug.log. When the recorder sends a mail, it creates entries like 02.10.20 07:45:12.935 TSMTPMailer SmtpRequestDone 0 - 0 02.10.20 07:45:12.963 TSMTPMailer SmtpRequestDone 10 - 0 02.10.20 07:45:13.072 TSMTPMailer SmtpRequestDone 12 - 0 02.10.20 07:45:13.182 TSMTPMailer SmtpRequestDone 10 - 0 02.10.20 07:45:13.327 TSMTPMailer SmtpRequestDone 11 - 0 02.10.20 07:45:13.531 TSMTPMailer SmtpRequestDone 9 - 0 02.10.20 07:45:13.574 TSMTPMailer SmtpRequestDone 6 - 0 Are they present? The first number indicates the type of request, the second one is an error code. 0 means no error. Quote
Qosmio Posted October 2, 2020 Author Posted October 2, 2020 Fresh installed both DVBViewer and recorder service and the issue is resolved. Thanks for your help and have a great weekend. Quote
Griga Posted October 2, 2020 Posted October 2, 2020 27 minutes ago, Qosmio said: Fresh installed both DVBViewer and recorder service The old Recording Service or the DVBViewer Media Server? Using the old Recording Service together with an up-to-date DVBViewer version is no good idea... Quote
Qosmio Posted October 2, 2020 Author Posted October 2, 2020 No i installed dvb media server ofcource its habbit to call it recording service sorry about that. Quote
