TBS-6590 No skan DVB-S2
il diavolo epm
Hello,
Please
I have a TBS-6590 card
I can't scan any DVB-S2 channels
I don't know if there is voltage in the LNB
Are you sure this card with this software works with DVB-S2?
Thank you
TBS 6590 is one of the so-called multi-standard cards, that has to be configured for the desired reception type (DVB-S/T/C...) by using a TBS Change Mode Tool (IMO a bad design). Have you already done it? If not, download the tool from here. After using it, perform Options -> Hardware -> Scan Devices in DVBViewer.
Yes, I have, but I'm going to have other problem there....Thanks
