Retrofan Posted October 4, 2020 Posted October 4, 2020 DVBViewer Pro doesn't handle LCN, but maybe when LCN is scanned by TransEdit it can be added this way to DVBViewer Pro with an option in TransEdit? Example: #EXTINF:-1,ARD #EXTVLCOPT:program=19192 rtsp://192.168.0.4:554?freq=290&msys=dvbc&sr=6900&mtype=256qam&pids=0,16,17,18,20,5300,5301,5401,5311 Will then be for DVBViewer Pro: #EXTINF:-1, (100) ARD #EXTVLCOPT:program=19192 rtsp://192.168.0.4:554?freq=290&msys=dvbc&sr=6900&mtype=256qam&pids=0,16,17,18,20,5300,5301,5401,5311 Where 100 is the LCN. Good idea? Quote
Retrofan Posted October 5, 2020 Author Posted October 5, 2020 (edited) Probably this is easy to implement inside TransEdit for now as workaround I guess... ? Edited October 5, 2020 by Retrofan Quote
Griga Posted October 6, 2020 Posted October 6, 2020 You want the logical channel number to be optionally prepended to the channel name. Why specifically in M3U exports? For which use case? Quote
Retrofan Posted October 6, 2020 Author Posted October 6, 2020 11 hours ago, Griga said: You want the logical channel number to be optionally prepended to the channel name. Why specifically in M3U exports? For which use case? Yes, that's right. As workaround for DVBViewer Pro to show LCN and M3U as fileformat as with INI file the LCN is ignored by DVBViewer. M3U is well supported. Quote
Retrofan Posted February 7, 2021 Author Posted February 7, 2021 On 10/6/2020 at 7:29 AM, Griga said: You want the logical channel number to be optionally prepended to the channel name. Why specifically in M3U exports? For which use case? This could be handy when using other applications like Simple IPTV client in KODI. https://kodi.wiki/view/Add-on:PVR_IPTV_Simple_Client If you could export the LCN number in the M3U files as well to this tag, then it would be great! -> tvg-chno This is for TransEdit which can export to SAT>IP M3U. Quote
