rodjd Posted December 27, 2020 Posted December 27, 2020 (edited) DVBViewer 7 not work in windows 10 2004,21277.1000 with Cinergy C PCI Digital Tuner, driver terratec 01.12.2019 12:37 2309792 Cinergy_C_PCI_HC_Drv_Setup_1.01.02.501_XP_Vista_7_8_64Bit.exe i whait another windows build to see if microsoft or terratec resolve this BUG ! Or it is BUG DVBViewer ??? ... AMD R9 270x ,driver 20.12.1 Windows insiders 2004,21277.1000,x64 TerraTec TV Cinergy C PCI DVB-C support.zip Edited December 28, 2020 by rodjd png and zip support Quote
Griga Posted January 5, 2021 Posted January 5, 2021 Unfortunately there is no DVBViewer.log in your support.zip, because you did not reproduce the problem in DVBViewer debug mode. Please follow the instructions given here. The DVBViewer.log will probably show which kind of error occurs. Quote
rodjd Posted January 5, 2021 Author Posted January 5, 2021 (edited) i send you zip,i open dvb in start debug,i close dvb and open tools where it is dvb install,i can search tv chanell because this bug Edited January 5, 2021 by rodjd Quote
rodjd Posted January 5, 2021 Author Posted January 5, 2021 (edited) you dont respond to message ! team from DVBViewer you see bugs from pro user ? Please update GUI it is very old support.zip Edited January 5, 2021 by rodjd Quote
Griga Posted January 5, 2021 Posted January 5, 2021 No support via personal message! This is the error from the DVBViewer.log: Zitat 05.01.21 11:30:15.255 TBDATwinhan OpenDevice Cinergy C PCI Digital Tuner did not start: bvTwinhan DVBViewer cannot start your Cinergy C PCI. This is an error outside DVBViewer in the driver or the Windows BDA system. Maybe the driver does not work under Windows 10 2004 anymore, so you have to buy a new DVB C card. Or you need to perform a Windows 10 repair installation for getting the BDA system fixed. Anyway, what I would try first is to uninstall and delete the driver, then reboot and install it again. Quote
rodjd Posted January 5, 2021 Author Posted January 5, 2021 thank you for late reply and sorry for message,i can update BDA driver ,where i found ? Quote
Griga Posted January 5, 2021 Posted January 5, 2021 vor 15 Minuten schrieb rodjd: i can update BDA driver ,where i found ? As far as I can see there is no newer BDA driver than the one that you are using (Cinergy_C_PCI_HC_Drv_Setup_1.01.02.501_XP_Vista_7_8_64Bit.exe). Quote
RomanSin Posted January 7, 2021 Posted January 7, 2021 (edited) You should try to use the attached AzureWave driver instead of Terratec one. In the end of the 00s there was a set of identical Twinhan-based digital TV tuners issued by several manufacturers (TechniSat, Terratec, etc.), the AzureWave driver was the best for all of them. AzureWave Mantis.zip Edited January 7, 2021 by RomanSin Quote
