How to disable Channel Numbers in on screen mini EPG window
Qosmio
How can i disable Channel Numbers from showing in the on screen mini EPG window when using favorites only channels, the old DVBViewer version 6 did not have that now with version 7 it shows a * plus the number.
Thanks
C:\Program Files (x86)\DVBViewer\OSDSkins\Default\myMiniEPG.xml
Remove the following lines from the file and restart DVBViewer.
Spoiler
    <item>
      <description>default label</description>
      <type>Label</type>
      <id>1</id>
      <disabledcolor>60FFFFFF</disabledcolor>
      <x>178</x>
      <y>478</y>
      <width>97</width>
      <height>40</height>
      <label>#channelnr</label>
      <font>DefaultFont</font>
      <textcolor>FFB4B4B4</textcolor>
      <textselectedcolor>FF202020</textselectedcolor>
      <align>right</align>
      <verticalalign>left</verticalalign>
    </item>
Please note that you have to repeat it after each DVBViewer update. So better make a backup of the modified file.
  • Like 1
Thanks Griga, i use other skin but but i get the idea and find the part i should remove in the xml file it uses.
Best Wishes for 2021
