Timer name - sometimes out of sync while recording
Langhuse
I have noticed that the timer name sometimes is incorrect.
  • the timer name can change before/while recording (not sure when)
  • the recording filename is correct
  • the recording in the recordinglist is correct
Here is one example
(1) EPG info is correct
(2) filename on the file system is correct
(3) timername is incorrect. It uses the title from the programme sent just before this recording
Here is one example
I recall (not very strongly) that I have been confused before because some recordings in the recording list had the wrong name (not sure my memory is correct).
No big deal, I just wonder if the "EPG name", "Timername", "Recording titel" and "Filename" can get out of sync
A happy new year to all of you
Poul
I have 3.0.0.0
Sorry, did not check or see the two day old version 3.0.1, released 30/12 ?
Will install, and I see that it now also fixes my tuner problem.
Thanks - and a happy new year ?
poul
