Time format in web Media Server page (shows AM/PM time instead 24hour format)
Alan_SP
Latest versions (not the latest beta, but 7.0.1.0 and 3.0.1.0), and I just noticed that time I see is in am/pm format. In Windows it is Croatian time settings (24hour time format), and didn't find setting where to change time format to 24hour one.
It's reflected everywhere, timers, recordings, timeline, etc.
Is there easy way to get 24hour format?
The Media Server is running as a Windows service in the system account, so you need to change the format settings of the system account. It can be done by copying the settings of your user account to the system account on the Administrative tab of the Region settings dialog. Please read more about it here. The language for non-Unicode programs on the same tab should also be changed to Croatian, if necessary.
In most Windows installations the system account format settings are already set up correctly. However, particularly some OEM installations leave them in the default state (USA settings), so they must be adjusted.
  • Like 1
Thanks Griga, this solved it, I just needed to restart server also, to propagate changes. Now everything works as it should.
