Carlton Posted January 20, 2021 Posted January 20, 2021 (edited) I'm new to DVBViewer, and would therefore like to enquire whether it is possible to save, along with a recorded programme video file, the EPG 'long form' data that directly relates to this particular programme, say an .xml file. I'm currently, for the time being, using the DVBViewer v7 Demo version, if that makes a difference. Many thanks Edited January 20, 2021 by Carlton Quote
YARD2 Posted January 20, 2021 Posted January 20, 2021 In the recording option you can check "Create EPG Info file". This will add a txt file to the video file. Quote
Carlton Posted January 21, 2021 Author Posted January 21, 2021 Many thanks for this information . . . but unfortunately I'm unable to locate the "Create EPG Info file" check box. Quote
YARD2 Posted January 21, 2021 Posted January 21, 2021 "Create EPG information file" is already checked. Then it should be txt file in the same folder as your video file Quote
HaraldL Posted January 21, 2021 Posted January 21, 2021 It's already checked in your picture. Box "Settings", first entry on the right column "Create EPG information file". So there should be a txt file beside every recording with a content like: [General] Version=1.1 [Media] Created=16.01.2021 20:10:01 Channel=TELE 5 [0] Id=42690 Date=16.01.2021 Time=20:15:00 Duration=01:45:00 Title=Fürst der Finsternis Info=Fürst der Finsternis, RUS 2017 Description=xxxx THIS IS THE EPG info xxxx Quote
Carlton Posted January 21, 2021 Author Posted January 21, 2021 Arr, sorry, my fault. Many thanks Quote
