Problems after Windows 10 update
BmacG
Hi All,
I have been using DVBViewer Pro for over a year without any problems. I run it on Windows 10 Home version. I recently updated Windows 10 to the 20H2 version, and since then DVBViewer does not run properly. Both the image and the audio are broken and intermittent.
I have installed the latest version of DVBViewer, and I have updated my video and audio drivers, but this has not helped.
Any assistance would be greatly appreciated.
Your DVB device is which one?
The issue is a known "feature" of recent Windows 10 versions since the 2004 update. Some DVB device drivers don't work properly anymore. So you need a more up-to-date driver or a new DVB device or to return to the previous Windows 10 version.
If it is Digital Devices HW, you need to run DDControlCenter after upgrade
