OS Support (Windows IoT, ReactOS)
Hello, everyone,
has, please, anybody tested DVBViewer (and the other SW) on the Windows IoT OS, or even ReactOS?
https://developer.microsoft.com/en-us/windows/iot/
https://en.wikipedia.org/wiki/Windows_IoT
https://reactos.org/
https://distrowatch.com/reactos
https://en.wikipedia.org/wiki/ReactOS
The goal is setting up a system as lightweight and as quick and responsible as possible.
THANK YOU.
Best!
ReactOS will not work, due to limited driver support and compatibility issues.
I am running a DMS client on Windows 10 IoT Enterprise 2016 LTSB and it works great. No nasty upgrade notifications etc.
But thats the only difference to a normal Windows 10 edition. The binaries are the same. The only thing thats better is that WIndows Updates are easier to control.
Edited by esackbauer
add
@esackbauer
THANK YOU for the positive info! Pity there's no DVBViewer for Linux and the ARM architecture - one could get it run on Raspberry Pi and such...
Edited by RMC
