jirim100 Posted May 30, 2021 Posted May 30, 2021 (edited) DMS 3.0.1.3 hangs at the end of recording (and don't start post recording task) -> then Windows 10 system restart. Here is the output from analyzing operating system crash dump file in WinDbg.exe application. Support.zip is attached. Crash happened about 30.05.2021 13:30:50. I don't expect you solve this problem (or maybe (?) wrap affected code around by try,catch,finally), but I think, you should be at least to know about it. Spoiler Microsoft (R) Windows Debugger Version 10.0.19041.685 AMD64 Copyright (c) Microsoft Corporation. All rights reserved. Loading Dump File [C:\Windows\Minidump\053021-11375-01.dmp] Mini Kernel Dump File: Only registers and stack trace are available Symbol search path is: srv* Executable search path is: Windows 10 Kernel Version 19041 MP (20 procs) Free x64 Product: WinNt, suite: TerminalServer SingleUserTS Built by: 19041.1.amd64fre.vb_release.191206-1406 Machine Name: Kernel base = 0xfffff807`13a00000 PsLoadedModuleList = 0xfffff807`1462a390 Debug session time: Sun May 30 13:30:10.101 2021 (UTC + 2:00) System Uptime: 18 days 0:17:56.813 Loading Kernel Symbols ............................................................... ................................................................ ................................................................ ................ Loading User Symbols Loading unloaded module list .................................................. For analysis of this file, run !analyze -v 18: kd> !analyze -v ******************************************************************************* * * * Bugcheck Analysis * * * ******************************************************************************* SYSTEM_SERVICE_EXCEPTION (3b) An exception happened while executing a system service routine. Arguments: Arg1: 00000000c0000047, Exception code that caused the bugcheck Arg2: fffff80713cee8ba, Address of the instruction which caused the bugcheck Arg3: fffff8876e6ae460, Address of the context record for the exception that caused the bugcheck Arg4: 0000000000000000, zero. Debugging Details: ------------------ *** WARNING: Unable to verify timestamp for emBDA64.sys KEY_VALUES_STRING: 1 Key : Analysis.CPU.Sec Value: 2 Key : Analysis.DebugAnalysisProvider.CPP Value: Create: 8007007e on DESKTOP-B7NHU71 Key : Analysis.DebugData Value: CreateObject Key : Analysis.DebugModel Value: CreateObject Key : Analysis.Elapsed.Sec Value: 20 Key : Analysis.Memory.CommitPeak.Mb Value: 81 Key : Analysis.System Value: CreateObject BUGCHECK_CODE: 3b BUGCHECK_P1: c0000047 BUGCHECK_P2: fffff80713cee8ba BUGCHECK_P3: fffff8876e6ae460 BUGCHECK_P4: 0 CONTEXT: fffff8876e6ae460 -- (.cxr 0xfffff8876e6ae460) rax=0000000000000000 rbx=0000000000000001 rcx=ffffcc0380849d10 rdx=fffff8876e6ae600 rsi=0000000000000001 rdi=0000000000000001 rip=fffff80713cee8ba rsp=fffff8876e6ae9a0 rbp=ffff9f00765c0180 r8=fffff8876e6ae5f8 r9=0000000000000000 r10=00000000000007d0 r11=000000000000002c r12=0000000000000000 r13=ffffffffffffffff r14=0000000000000000 r15=0000000000000010 iopl=0 nv up ei ng nz na po nc cs=0010 ss=0018 ds=002b es=002b fs=0053 gs=002b efl=00040286 nt!RtlRaiseStatus+0x4a: fffff807`13cee8ba 80c3ff add bl,0FFh Resetting default scope BLACKBOXBSD: 1 (!blackboxbsd) BLACKBOXNTFS: 1 (!blackboxntfs) BLACKBOXPNP: 1 (!blackboxpnp) BLACKBOXWINLOGON: 1 CUSTOMER_CRASH_COUNT: 1 PROCESS_NAME: DVBVservice.exe STACK_TEXT: fffff887`6e6ae9a0 fffff807`13cee6c6 : ffffdf04`85d96050 fffff807`2aabf4e2 00000000`00000002 ffffdf04`85d96100 : nt!RtlRaiseStatus+0x4a fffff887`6e6aef40 fffff807`2aa9fc31 : ffffdf04`85d96100 ffffdf04`85d96000 ffffdf04`85d96000 ffffdf04`66337000 : nt!KeReleaseSemaphore+0x166 fffff887`6e6aefc0 ffffdf04`85d96100 : ffffdf04`85d96000 ffffdf04`85d96000 ffffdf04`66337000 fffff887`00000002 : emBDA64+0x6fc31 fffff887`6e6aefc8 ffffdf04`85d96000 : ffffdf04`85d96000 ffffdf04`66337000 fffff887`00000002 fffff887`6e6af060 : 0xffffdf04`85d96100 fffff887`6e6aefd0 ffffdf04`85d96000 : ffffdf04`66337000 fffff887`00000002 fffff887`6e6af060 00000000`00000000 : 0xffffdf04`85d96000 fffff887`6e6aefd8 ffffdf04`66337000 : fffff887`00000002 fffff887`6e6af060 00000000`00000000 ffffdf04`68c26120 : 0xffffdf04`85d96000 fffff887`6e6aefe0 fffff887`00000002 : fffff887`6e6af060 00000000`00000000 ffffdf04`68c26120 ffffdf04`66337000 : 0xffffdf04`66337000 fffff887`6e6aefe8 fffff887`6e6af060 : 00000000`00000000 ffffdf04`68c26120 ffffdf04`66337000 fffff807`2aaa9b15 : 0xfffff887`00000002 fffff887`6e6aeff0 00000000`00000000 : ffffdf04`68c26120 ffffdf04`66337000 fffff807`2aaa9b15 00000000`00000000 : 0xfffff887`6e6af060 SYMBOL_NAME: emBDA64+6fc31 MODULE_NAME: emBDA64 IMAGE_NAME: emBDA64.sys STACK_COMMAND: .cxr 0xfffff8876e6ae460 ; kb BUCKET_ID_FUNC_OFFSET: 6fc31 FAILURE_BUCKET_ID: 0x3B_c0000047_emBDA64!unknown_function OS_VERSION: 10.0.19041.1 BUILDLAB_STR: vb_release OSPLATFORM_TYPE: x64 OSNAME: Windows 10 FAILURE_ID_HASH: {a1d80dad-652a-fbbf-75a2-09405f732c27} Followup: MachineOwner --------- 18: kd> lmvm emBDA64 Browse full module list start end module name fffff807`2aa30000 fffff807`2ab23000 emBDA64 T (no symbols) Loaded symbol image file: emBDA64.sys Image path: \SystemRoot\System32\drivers\emBDA64.sys Image name: emBDA64.sys Browse all global symbols functions data Timestamp: Mon Apr 6 06:26:19 2020 (5E8AAF6B) CheckSum: 000FB0DF ImageSize: 000F3000 Translations: 0000.04b0 0000.04e4 0409.04b0 0409.04e4 Information from resource tables: support.zip Edited May 30, 2021 by jirim100 Quote
Griga Posted May 30, 2021 Posted May 30, 2021 Looks like the driver for your Hauppauge WinTV-soloHD (emBDA64.sys) crashed when the DMS tried to release the device: 30.05.21 13:30:02.100 TRecording Release Hauppauge WinTV-soloHD DVBT Tuner (11) 30.05.21 13:30:02.100 TRecording Free Hauppauge WinTV-soloHD DVBT Tuner (11) ... no regular end, because the last call does not return, thus completely blocking the DMS 30.05.21 13:31:03.476 Start App ------------------------------------------------------------ 30.05.21 13:31:03.476 DVBViewer Media Server 3.0.1.3 "em" in emBDA64.sys stands for eMPIA. Actually it is no driver from Hauppauge, but from the chipset manufacturer. Quote
botti 56 Posted May 31, 2021 Posted May 31, 2021 Maybe a Driver update will help: https://www.hauppauge.com/pages/support/support.html#win10 Quote
jirim100 Posted May 31, 2021 Author Posted May 31, 2021 Version on this web "wintv-solo_dual_quadhd_5_2020_0406_38125.exe" (for "WinTV-soloHD") I have already installed. Quote
