yaRincewind Posted February 15, 2005 Posted February 15, 2005 Hi, it would be great if the OSD could appear on a second VGA Output. So one could use a remote Proggie (like VNC) to display only the OSD a stream this to a PocketPC or similar, to have a kind of "visuall touchscreen remote control". Would this be possible? Greetz, Rince Quote
Guest Lars_MQ Posted February 15, 2005 Posted February 15, 2005 Well in theory with the version 3.0 it would be possible, the OSD could be rendered to different destination. BUT sometimes there would be rendered about 25 pictures a second so it's quite theoretically... BUT it would be possible to make a webremotecontrol with the remote plugin. Mabe that's the better way to go. You would be able to control the viewer with every device having a webbrowser and a kind of LAN connection... Quote
yaRincewind Posted February 15, 2005 Author Posted February 15, 2005 Oh, you´re right. It is the more flexible way. If the engine is powerfull enough to controll everything nut only the PVR, it is the much better way. Quote
