DVBSky T330
jirim100
Strange thing with device DVBSky T330 - it's for DVB T/T2 and C.
I tune/record channel in DVB T (successfully) then I want tune/record channel in DVB C - without success (no data/connected/signal 0%).
But when I reinstall driver (last for Win10: http://www.dvbsky.net/download/win10drv_180820.zip) then I can tune/record channel in DVB C.
But after it I can't tune/record channel in DVB T. Therefore I have to reinstall driver - > now I can tune/record channel in DVB T.
But after it I can't tune/record channel in DVB C. Therefore I have to reinstall driver - > now I can tune/record channel in DVB C.
And again and again...
I would like to use both: DVB T/T2 and C, not only one of them.
DMS 3.0.1.3
6 hours ago, jirim100 said:
But when I reinstall driver then I can tune/record channel in DVB C.
Try if you can achieve the same by disabling and re-enabling the device in the Windows device manager (which resets the device and driver).
Often such hybrid tuner sticks are not designed for on-the-fly DVB-T/C changes, particularly because you can't connect them to a DVB-T and DVB-C antenna at the same time. Once a DVB-T or DVB-C channel has been tuned, they kind of lock the first selected mode.
Disabling/enabling device in Windows device manager solve this problem. Can you add this tweak into sw ? ?
Device "Hauppauge WinTV-soloHD" don't have this problem. My broadcast provider have in one cable DVB-T and DVB-C together.
Strange, today it stop working after about 10 changes DVB-T -> DVB-C -> ...
I install DVBSky Player (probably created by Christian Hackbart) and switching between DVB-T and DVB-C working a little bit better (no need disable/enable device).
Edited by jirim100
You can use DeviceReset_64.exe (for 64 bit Windows, see DVBViewer program directory, installed with the DMS), e.g. by creating a batch file with a single line
DeviceReset_64.exe "Device_ID"
as content, where "Device_ID" is the section name of the device from your (svc)hardware.xml, like
DeviceReset_64.exe "@device:pnp:\\?\usb#vid_0b48&pid_3014#20131128#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{f31bcf3b-9623-4937-8228-bd895ba00b61}"
Replace all XML encoded & by the original &. The batch file must be executed with admin rights or by the DMS running as service in the system account. The DMS uses DeviceReset_64.exe for Options -> Hardware -> Reset after sleep/hibernate (only visible if the options are launched with admin rights) and for the tweak "Reset DVB device before recording" (-> launch DMSTweaker.bat, read the description for the tweak at the bottom).
I think, enabling this tweak (plus enabling "Reset after sleep/hibernate" for this tuner) will be enought for this. Thanks.
The batch file as external task would enable launching it manually in the web interface -> Tasks. See DMS options with admin rights -> Tasks -> New -> enter your stuff.
Yes. But I don't want to think about when I have to run this task.
Enabling globally this tweak is not probably good idea, I get today two BSOB (source: tuner AverMedia TD310 ).
Probably restart of this device overlapping with start of recording. But Hauppauge WInTV-solo HD works with this tweak without problem (and in .log aren't messages Removed/Arrived for this device when is restarted).
Spoiler
24.06.21 10:06:37.761 TWinApp              Execute          C:\Program Files (x86)\DVBViewer\DeviceReset_64.exe
24.06.21 10:06:37.761 TWinApp              Working Directory C:\Program Files (x86)\DVBViewer\
24.06.21 10:06:53.250 ResetDevice          @device:pnp:\\?\usb#vid_07ca&pid_1871#202374500362#{71985f48-1ca1-11d3-9cc8-00c04f7971e0}\{cacacefd-1b5f-49f4-af24-0ce559cc1f6d}
-1
24.06.21 10:06:56.338 TBDAAverMedia        OpenDevice       bvAverMedia
24.06.21 10:06:56.338 TRecording           AllocateHardware AVerMedia TD310 BDA Filter (2)
24.06.21 10:06:56.338 TRecording           StartRecording   AVerMedia TD310 BDA Filter (2)
24.06.21 10:06:56.338 TBDAAverMedia        SetTuner         TType: 2, Freq: 514000, Symrate: 0, LOF: 0, Tone: 0, Pol: 2, DiseqC: 0, FEC: 0, APID: 2620, VPID: 2610, PMT: 2600, SID: 278, TID: 8465, NID: 8395, SatMod: 0, DiseqCVal: 0, Flags: 24, Group: 6
24.06.21 10:06:58.019 TRecording           StartRecording:  CT 3 HD T2
24.06.21 10:06:58.020 SendUpdate           DVBVUPDATE TMR
24.06.21 10:06:58.024 SendUpdate           DVBVUPDATE REC
24.06.21 10:06:58.024 DeviceChange         AVerMedia TD310 BDA Filter (2) Removed
24.06.21 10:06:58.024 DeviceChange         AVerMedia TD310 BDA C Filter (1) Removed
24.06.21 10:06:58.024 DeviceChange         AVerMedia TD310 BDA Filter (2) Arrived
24.06.21 10:06:58.024 DeviceChange         AVerMedia TD310 BDA C Filter (1) Arrived
24.06.21 10:06:58.025 SendUpdate           DVBVUPDATE RST 4109
24.06.21 10:08:11.385 TRecording ($02441250)    Tick             No data within one minute, restarting!
24.06.21 10:08:11.385 TRecording ($02441250)    W:\For The Record\Stačí stisknout; film; ČSR; 1989; vysíláno 2021-06-24 T2_01.aac Discontinuities: 0  -  Total size: 0,00 KB  -  Device: AVerMedia TD310 BDA Filter (2)
24.06.21 10:08:11.385 SendUpdate           DVBVUPDATE REC
24.06.21 10:09:03.240 Start App            ------------------------------------------------------------
