hpr Posted June 27, 2021 Posted June 27, 2021 If I have issues transitioning to MS can I quickly/simply go back to using my currrent RS installation? I'm not sure if I really need the full MS. Actually, I only really need MS as RS is no longer supported and minor problem has cropped up with it. Quote
Griga Posted June 27, 2021 Posted June 27, 2021 2 hours ago, hpr said: can I quickly/simply go back to using my currrent RS installation? To be on the safe side, I would use a system restore point, plus a backup of the whole DVBViewer/DMS configuration folder (C:\ProgramData\CMUV\DVBViewer). Please note that DVBViewer should be updated to the latest version before installing the DMS. Quote
hpr Posted June 27, 2021 Author Posted June 27, 2021 (edited) Thanks, I think I will try it on seperate computer first! Edited June 27, 2021 by hpr spelling Quote
