DMS - no discontinuities in recorded stream
jirim100
Hello.
Is it possible to have recorded stream without discontinuities (DMS 3.0.1.3), but the video contains some disruptions? Is it possible my broadcaster broadcast flawy stream?
Example of log file (without errors) of the recording (device Hauppauge WinTV-soloHD DVBT tuner):
Spoiler
CT 1 03.07.2021
W:\For The Record\Z metropole; 2021-07-03.ts
Naming Scheme: %name; %year-%m-%d
Device: Hauppauge WinTV-soloHD DVBT Tuner (7)
EventID: 1390632960
Timer Name: Z metropole
Timer Start: 03.07.2021 11:45:00
Timer Duration: 00:56:00 (56 min. incl. 15 min. lead time, 15 min. follow-up time)
Timer Options: Teletext=1, DVB Subtitles=1, All Audio Tracks=1, Adjust PAT/PMT=1, EIT EPG Data=1, Transponder Dump=0
Timer Source: Search:Z metropole
11:45:03 / 00:00:00 (~ 0,00 MB) Start Recording
11:45:03 / 00:00:00 (~ 0,00 MB) Týden v regionech not running | EventID: 15734 PDC: 0x00000
11:45:03 / 00:00:00 (~ 0,00 MB) EventID change 1390632960 to 15734
11:45:04 / 00:00:01 (~ 0,56 MB) PID 1101: MPEG2 Video, 16:9, 720x576, 25 fps
11:45:04 / 00:00:01 (~ 0,56 MB) PID 1103: MPEG Audio Stereo, 48 khz, 128 kbps
11:45:04 / 00:00:01 (~ 0,56 MB) PID 1102: MPEG Audio Stereo, 48 khz, 128 kbps
11:45:04 / 00:00:01 (~ 0,56 MB) PID 1104: MPEG Audio Mono, 48 khz, 64 kbps
11:45:04 / 00:00:01 (~ 0,56 MB) PID 1105: Videotext
11:45:04 / 00:00:01 (~ 0,56 MB) PID 1106: DVB Subtitles
11:45:05 / 00:00:01 (~ 0,56 MB) Všechnopárty running | EventID: 15729 PDC: 0x00000
12:00:14 / 00:15:11 (~ 536,86 MB) Týden v regionech running | EventID: 15734 PDC: 0x00000
12:00:15 / 00:15:12 (~ 537,44 MB) Hobby naší doby - letní speciál not running | EventID: 15735 PDC: 0x00000
12:25:15 / 00:40:11 (~ 1422,19 MB) Hobby naší doby - letní speciál running | EventID: 15735 PDC: 0x00000
12:25:16 / 00:40:12 (~ 1423,39 MB) Postřehy odjinud not running | EventID: 15739 PDC: 0x00000
12:41:01 / 00:55:58 (~ 1981,17 MB) Stop
Average Data Rate: 0,590 MB/s
Total Size: 1981,2 MB (2077409212 Bytes)
And here are some disruptions:
Edited by jirim100
Yes. Discontinuities only refer to missing transport stream packets, but not to video data within the transport stream packets, that may also be corrupted / distorted for some reason without missing TS packets.
Sure. Broadcasters aren't perfectly error-free. They also get the stream from somewhere, e.g. a DVB-T provider via satellite. Even with a professional 200 cm dish reception may be disturbed temporarily by a thunderstorm, for example. Clouds with a thickness of some kilometres absorb everything.
