Conflict autotimer with disabled timer.
jirim100
Hello.
I have this disabled timer:
Plus I have this search preset:
Plus these EPG data:
Why search preset "Z metropole" don't create timer for EPG record "Z metropole" ?
Why I have to firstly completelly delete disabled timer "Čarodějné námluvy/ct1_sd_dvbt_12-13h" before successfully aplying search preset "Z metropole"?
DMS 3.0.1.3
That is intended. The auto timer function does not create timers that already exist, no matter if they are enabled or disabled. DMS assumes timers to be the same if the channels are identical and the start/end time intervals overlap sufficiently (provided PDC or the event ID is not used for comparison).
