DVB CLOSE ERROR 1279
DVVVBAS
Hello, i use a long time DVBViewer and last days after i open a program 2 minuts this close and i receive info" user data error 1279:please use keytool.exe to enter de correct data"...I have a genuine key and i use version 5.1.0 . If anyone can help me i appreciate it! Sorry my english :).Thanks
When did it happen for the first time? Do you know the date?
You can get more information about this error by searching with Google for site:dvbviewer.tv user data error 1279.
Hello, first time happen in last monday! Now i try re install and have same problem, i instal version 7.0 problem is slove, but when i use some diferentes plug in image stop, só i need version 5.1.0, i try search for this version in fórum to dwonload and i can not find this :/…
This version 6.1.7.2 i have same problem when i use some plug ins image stoped, maybe need a stronger cpu for this version! I have version 5.1.0 have many years, i try in past version 6.1.5 and i have same problem when i use some plug ins image freeze..
When you look in DVBViewer program folder (should be C:\Program Files (x86)\DVBViewer) is there a "setup" folder in it? Perhaps there are the older installers you used on this machine.
