Radio Stream makes DVBViewer crash/unresponsive
bccrew
I have added several URL's as channels in my DMS setup. When I start DVBViewer on a radio channel on satellite, I can switch easily to this stream:
http://rrr.sz.xlcdn.com/?account=fmbrussel&file=fmb988.mp3&type=live&service=icecast&protocol=http&port=8000&output=pls
After that, I switch to another channel without issues
http://radio.canstream.co.uk:8022/live.mp3
But when I want to switch back to the earlier stream, DVBViewer client hangs.
I can reproduce it every time, again and again. I have not tested earlier versions then the latest.
Please advise
Logs:
https://www.dropbox.com/s/8fz56wcfxdw2f16/DVBViewer.log?dl=0
According to the log both live streams are flagged wrongly as "play as file" in the channel editor. Why? I can reproduce the issue under this condition. However, if the streams are flagged correctly, no crash occurs here.
Nevertheless DVBViewer shouldn't crash even if the streams are flagged wrongly. Will be investigated...
Ok, unticking the play as file works for me as well. Thanks!
