Vesa Komulainen Posted October 3, 2021 Posted October 3, 2021 I have been running DVBViewer for a few weeks now (and like the program very much as such), but a couple of times Windows has crashed and the culprit has been it9300bda.sys. I guess this must somehow be connected with DVBViewer - does anyone have a clue as to how to try and solve the problem? Quote
Griga Posted October 3, 2021 Posted October 3, 2021 3 minutes ago, Vesa Komulainen said: it9300bda.sys Most likely it's the BDA driver of your (USB) DVB device that crashes Windows. An application can't cause a blue screen. Quote
Vesa Komulainen Posted October 10, 2021 Author Posted October 10, 2021 On 10/3/2021 at 9:41 PM, Griga said: Most likely it's the BDA driver of your (USB) DVB device that crashes Windows. An application can't cause a blue screen. Just replaced the TV Butler USB tuner (which was causing the problems) with Hauppauge WinTV-dualHD. Running very smoothly now, also switching between channels which often used to be a pain with TV Butler is now always instantaneous. And - DVBViewer feels way better than WinTV... Quote
