Where can I find the latest transponder for satellite?
Sean99
Hi
Can anybody help me?
Where can I find the latest transponder for satellite? I am looking for the latest transponder for Arab sat satellite.
Thanks
36 minutes ago, Griga said:
https://en.kingofsat.net/satellites.php
Click the disk symbol to download the transponder list. Please note that is must be stored in the Transponders sub-directory of the DVBViewer configuration folder (see Windows start menu -> DVBViewer).
Thanks a lot. I downloaded it and it is ini file.
Should I copy this file to this path?
C:\ProgramData\CMUV\DVBViewer\Transponders
Yes. After that it should show up in DVBViewer -> TV/Radio -> Reception Settings/Channel Search -> Select DVB-S as Reception Type -> Select the transponder list -> adjust LNB Type and DiSEqC if necessary -> click Save -> click Scan.
Thank you so much
