amigace Posted February 17, 2005 Posted February 17, 2005 (edited) Concerning DVBViewer 3.0 when adding more than 1 directory to the Music Virtual-Path the checkmark in front of the entries cannot be set. Only 1 checkmark for the whole list is accepted. In the OSD unexpected all entries are present, no matter if the checkmark is set/not set. This applies to Movies & Pictures too. /EDIT seems that the checkmark sets the directory in which the HTPC starts when selecting music/movies/pictures, can anyone confirm this? Although it is not possible to deselect all checkmarks, so that the HTPC starts in the 'root' of all the listed directories. ... Edited February 17, 2005 by amigace Quote
Guest Lars_MQ Posted February 18, 2005 Posted February 18, 2005 It's no bug, it's a feature With Virtual Path you can group several directories or drives (even networked directories/drives) into a logical group. This is easier and cleaner to control via OSD, you only see these directories and can navigate much faster. At least one path must be checked, this will be the default path. Quote from the helpfile I hope to publish today or tomorrow (the german Version is already out). This is a kind of preferred path. Maybe I should rethink this and allow no selected... lars Quote
