DMS not using second tuner?
Bart Zorn
Hello,
I asked this in the Kodi forum first, but was referred to this forum.
I am playing a channel and I start recording that channel. Next I stop the playback and (try to) start playing a another channel. Nothing happens and after a while I get an error that Playback failed.
Checking the log does not give me any clue. The log file is here: https://drive.google.com/file/d/1hREWErb...sp=sharing
As far as I can see from the Media Server web display, only one tuner is active, and the other idle. I would expect that DVBViewer/DMS would use the second channel for the other channel.
My hardware/software is:
Kodi 19.3, DVBViewer 7.1.2.1 with DMS 3.1.2.1
Digital Devices Cine S2 V7 dual DVB-S2 tuner with CI
Windows 10 Pro x64 with all updates
Core i3 CPU, 16 GB memory
Anyone any idea?
TIA,
Bart
vor 8 Minuten schrieb Bart Zorn:
Me neither. A support.zip (after reproducing the problem) would probably be more revealing.
  • 3 weeks later...
This problem seems to have disappeared after the upgrade to DVBViewer 7.2.0.0 and MediaServer 3.2.0.0
Regards,
Bart
