IPTV Request
cleggy
Hi can you help please.I have just purchased DVBViewer as it stated it supports iptv.I find it very diffficult to add my own iptv.Ideally it would be great if you can add a means of being able to add iptv lists by using api lines as well as m3u.Api only needs portal url username and password.Most iptv providers now only supply api login not m3u..So i would be obliged if you would consider adding this feature as soon as you can
to be honest I have no idea what you mean. You can import m3u playlists in the channel editor. This works fine with all kind of iptv services (starting from HLS based one and ending up with Dash Streams).
Christian
my question is can you use api lines ie xdtreme code logi in for iptb instead of just m3u urls
