Sean99 Posted March 10, 2022 Posted March 10, 2022 Hi How can I add my transponder to transponder lists? In Reception Types shows my Satellite card as DVB-s while it is DVB-s2, is it ok? Quote
Griga Posted March 10, 2022 Posted March 10, 2022 vor 3 Stunden schrieb Sean99: How can I add my transponder to transponder lists? Please use the transponder list editor and scanner tool TransEdit (download from the customer area). vor 3 Stunden schrieb Sean99: In Reception Types shows my Satellite card as DVB-s while it is DVB-s2, is it ok? Yes. Here DVB-S stands for "Satellite" in a general sense. Quote
Sean99 Posted March 10, 2022 Author Posted March 10, 2022 2 hours ago, Griga said: Please use the transponder list editor and scanner tool TransEdit (download from the customer area). Thanks How about if I have already downloaded it? How can I bring it to DVBViewer? Quote
Griga Posted March 10, 2022 Posted March 10, 2022 vor 2 Stunden schrieb Sean99: How can I bring it to DVBViewer? Please read the included ReadMe. 1 Quote
Sean99 Posted March 10, 2022 Author Posted March 10, 2022 (edited) 23 minutes ago, Griga said: Please read the included ReadMe. I dont have ReadMe file! where can I download? Edited March 10, 2022 by Sean99 Quote
Sean99 Posted March 10, 2022 Author Posted March 10, 2022 41 minutes ago, Griga said: Please read the included ReadMe. I need some info about Lead Time and Follow up options in Timer Recordings window, can I find it in Readme file? Quote
Griga Posted March 10, 2022 Posted March 10, 2022 vor 7 Stunden schrieb Sean99: I dont have ReadMe file! where can I download? It's part of the TransEdit_4_3_0.zip. You can download it in the customer area. 1 Quote
