j.puig Posted March 22, 2022 Posted March 22, 2022 It would be a good idea, on analyzer screen, to add analyzing time, like this: Quote
EnoSat Posted August 16, 2024 Posted August 16, 2024 Is it possible to find out why TransEdit displays this message after the last Windows update? In doing so, DVBViewer starts normally. Windows: Vydanie Windows 11 Pro Insider Preview Verzia Dev Dátum inštalácie 16. 8. 2024 Platnosť hodnotenia uplynie 16. 9. 2024 0:37 Zostava operačného systému 27686.1000 Rozhranie Windows Feature Experience Pack 1000.27686.1000.0 Quote
EnoSat Posted August 18, 2024 Posted August 18, 2024 (edited) 4.3.3 Version language : Angličtina (USA) CompanyName : Griga FileDescription : DVB Scanner & Analyzer FileVersion : 4.3.3.0 InternalName : TransEdit LegalCopyright : 2004-2024 by Griga & Lars LegalTrademarks : OriginalFilename : TransEdit.exe ProductName : TransEdit ProductVersion : 4.2 Comments support.zip Edited August 18, 2024 by EnoSat Quote
Griga Posted August 18, 2024 Posted August 18, 2024 Close TransEdit, drag and drop TransEdit.exe on Resizer.exe in the same directory. Is the TransEdit text size more than 100%? If yes: Set the TransEdit text size to 100%, click Apply and Save, and try again. Do you still get the error? Quote
EnoSat Posted August 18, 2024 Posted August 18, 2024 Hi, before show: after result - transedit start OK and run Thanks for the fix. Will it be possible to run further versions also in the user's font size? PS: There is a similar problem with TSPlayer, but after confirming OK the error message, the program starts Quote
Griga Posted August 18, 2024 Posted August 18, 2024 vor 1 Stunde schrieb EnoSat: Will it be possible to run further versions also in the user's font size? Usually I don't try to fix problems that only occur with Windows preview versions, because It may be a bug in Windows. The error address points to code that scales icons in TransEdit to another size (particularly those in the Analyzer tree view). Up to now it seems to work with all Windows versions except your Windows 11 preview. vor 1 Stunde schrieb EnoSat: There is a similar problem with TSPlayer You can use the same work-around for it. Quote
Griga Posted August 19, 2024 Posted August 19, 2024 vor 12 Stunden schrieb EnoSat: Will it be possible to run further versions also in the user's font size? Anyway, I've found a code adjustment that may help to avoid the issue. It's just a guess... you have to try, because I can't reproduce the problem. Please check it with the TransEdit 4.3.3.1 test version that I have sent to you as attachment of a personal forum message (PM). Quote
EnoSat Posted August 21, 2024 Posted August 21, 2024 After yesterday's storm, the PC is out of order and I don't know if it will still be functional, so I can't verify the status in Win11 at the moment. At most, I can try to set the Win7 raster to 125 in the notebook, as it was on the large PC. In 32b Win7 no version has problem with 125 raster 4320 - ok 4330 - ok 4331 - ok In 64b Win11 I can't verify anything yet Quote
Griga Posted August 21, 2024 Posted August 21, 2024 vor 3 Minuten schrieb EnoSat: In 32b Win7 no version has problem with 125 raster My guess was that it may have something to do with the bits per pixel in your Windows 11 preview version. TransEdit assumes 32 bit (true color), which is appropriate for almost all Windows installations. However, your last Windows update may have changed something in this respect. The test version now forces 32 bit color depth in the source bitmap before scaling it. Quote
EnoSat Posted September 2, 2024 Posted September 2, 2024 (edited) Now back 64b Win11 Pro Insider Preview (scale 125%) 4.3.3.1 work OK Edited September 2, 2024 by EnoSat Quote
Griga Posted September 3, 2024 Posted September 3, 2024 vor 10 Stunden schrieb EnoSat: 4.3.3.1 work OK Thanks for feedback! The fix will be part of the next release. Quote
