DVBViewer stopped working with [ removed, violating forum rule §13 ]?
OMETV ADMIN
hello,
i did a clean o.s installation. I reinstalled DVBViewer extracted my plugin ([ removed, violating forum rule §13 ]) files in program/DVBViewer/plugin , but seems it doesn't start anymore...
Maybe i remember bad how to install a plugin?
Any hint?
thanks
i need to install previous version of DVBViewer?
Which was your previous version and which is your new version? There have been no plugin interface changes in recent versions.
Please understand that we can't support the usage of plugins that are illegal in Germany. Only support for plugins in general  is possible.
i dont remember the exact previous version, but i installed it in oct 2020...  I would only know if in the recent version you have blocked [ removed, violating forum rule §13 ] plugins... thanks
i copied the exact plugin folder as i used with my previous o.s. installation...
Edited by HaraldL
Please don't circumvent plugin name blocking
now im on 7.2.1.0  the latest version.
i see plugins if i click on program infos but i dont see loaded in any menù
Edited by OMETV ADMIN
with version 6.0.2  it load this plugin
the strange thing is that last version it doesnt load also netstreaming plugin
i tried also downloading random plugin from members section (audiorecorder plugin) and it also isnt loaded... I should enable plugins in some section ?
i also dont know why it open in debug mode
vor 12 Stunden schrieb OMETV ADMIN:
What if the Audiorecorder Plugin is the only plugin? Here it appears in the plugins menu (besides other plugins) quite happily.
There is no blocking of certain plugins and no switch that disables or enables plugins. However, DVBViewer does not load plugins if it is launched with the -vanilla command parameter. The "DVBViewer Pro (Safe Mode)" item in the Windows start menu uses it.
vor 11 Stunden schrieb OMETV ADMIN:
What opens in debug mode?
i'm launching from start menù, and it starts (DVBViewer) in debug mode. Maybe this cause the plugins not loaded?
EDIT:  yes indeed if i start from program folder it loads plugins again
