EPG API Date format
SuppaMan
Hi!
I'd like to use the api provided with the Media Server to retrieve the current day's EPG, but i can't find any information on how to input the date in the query parameter.
The only information I got is that it is in float64, but I never hear of this format.
Can you help me?
vor 9 Stunden schrieb SuppaMan:
Since the Media Server is developed with Delphi, the API uses the Delphi TDateTime format:
https://docwiki.embarcadero.com/Libraries/Sydney/en/System.TDateTime
Searching the web for TDateTime yields more information, if you need it.
I think the API should be extended in a way that enables passing date and time in a more convenient format, e.g. something close to ISO 8601.
Thank you very much!
I agree that the date should be passed in a more common way, but for now... it works :)
vor 11 Minuten schrieb SuppaMan:
ISO date/time as input format will be available in the next release. It has been coded today :)
