SuppaMan Posted April 9, 2022 Posted April 9, 2022 Hi! I have a private HLS stream that works fine with all players (web based, android and ffmpeg). In DVBViewer, however, the stream stops and play in loop, jumping from a point to other. Inspecting the log, DVBViewer download (and play, I assume) already downloaded fragments, unlike other streams in which fragments are correctly downloaded once. I attach a filtered example:09.04.22 15:33:52.378 TBaseHTTPStream Connecting to https://example.com/hls/stream.m3u8 09.04.22 15:33:52.472 THLSStream Connecting to https://example.com/hls/stream-1635.ts 09.04.22 15:33:52.603 THLSStream Connecting to https://example.com/hls/stream-1636.ts 09.04.22 15:33:52.632 THLSStream Connecting to https://example.com/hls/stream-1637.ts 09.04.22 15:33:52.663 THLSStream Connecting to https://example.com/hls/stream-1638.ts 09.04.22 15:33:58.602 TBaseHTTPStream Connecting to https://example.com/hls/stream.m3u8 09.04.22 15:33:58.698 THLSStream Connecting to https://example.com/hls/stream-1636.ts 09.04.22 15:33:58.838 THLSStream Connecting to https://example.com/hls/stream-1637.ts 09.04.22 15:33:58.869 THLSStream Connecting to https://example.com/hls/stream-1638.ts 09.04.22 15:33:58.970 THLSStream Connecting to https://example.com/hls/stream-1639.ts 09.04.22 15:34:04.833 TBaseHTTPStream Connecting to https://example.com/hls/stream.m3u8 09.04.22 15:34:04.923 THLSStream Connecting to https://example.com/hls/stream-1636.ts 09.04.22 15:34:05.076 THLSStream Connecting to https://example.com/hls/stream-1637.ts 09.04.22 15:34:05.106 THLSStream Connecting to https://example.com/hls/stream-1638.ts 09.04.22 15:34:05.180 THLSStream Connecting to https://example.com/hls/stream-1639.ts 09.04.22 15:34:05.390 THLSStream Connecting to https://example.com/hls/stream-1640.ts I also noticed these line that occurs every redownload of the master playlist:09.04.22 16:24:46.933 TFileDevice CheckAutoRetune Retuning TS Stream Device 09.04.22 16:24:46.941 TFileDevice StopDevice 09.04.22 16:24:46.941 TFileDevice CloseDevice 09.04.22 16:24:55.221 TFileDevice CheckAutoRetune Retuning TS Stream Device 09.04.22 16:24:55.238 TFileDevice StopDevice 09.04.22 16:24:55.238 TFileDevice CloseDevice 09.04.22 16:25:03.540 TFileDevice CheckAutoRetune Retuning TS Stream Device 09.04.22 16:25:03.556 TFileDevice StopDevice 09.04.22 16:25:03.556 TFileDevice CloseDevice Can anyone help me figuring out this? Quote
Griga Posted April 10, 2022 Posted April 10, 2022 For analyzing this I need the m3u8 URL (for receiving the stream myself) or at least the TransEdit debug output (see here, "HTTP Debug Version" section). You can send me a PM, if you don't want to post it publicly. Quote
Griga Posted April 10, 2022 Posted April 10, 2022 Ok, got it. The stream contains corrupted time stamps, or more precisely, a corrupted PCR (Program Clock Reference, the broadcasted time base for video/audio timing). It's not increasing monotonically, as it should be. That's why the DVBViewer Filter (DVBSource) repeatedly sends PCR/PTS Gap error messages to the host application (DVBViewer), which in return tries to clear the whole thing by stopping and restarting playback. You can see it on the DVBViewer Filter Property Page. It's a consequence of "Check Timestamp Continuity" being ticked. The best way to fix it is to tick "Remove clock reference" in the DVBViewer Channel Editor for the channel in question. It lets DVBViewer simply remove the erroneous PCR, thus forcing the DVBViewer Filter to use the audio PTS (Presentation Time Stamps) as substitute time base, which seems to be ok. With this setting the stream plays continuously here. Quote
SuppaMan Posted April 10, 2022 Author Posted April 10, 2022 The fix is working perfectly, thank you very much! Next I'll try to fix the source stream problem, but for now it's ok Quote
