kmyne Posted February 21, 2005 Posted February 21, 2005 (edited) Hello, at first my compliments for DVBViewer. I just migrated from a Technotrend Premium DVB card and I am really impressed. Program functionalities extended with some plugins cover all my current requirements. DVBViewer 3.0 caused nonetheless a problem in combination with the NVidia audio filter. I'm using NVDVD 2.55 and I would like to use its video and audio filters for DVBViewer too. Some highlights of my current HW/SW configuration: ABIT AN7 Mainboard, Amplifier connected via optical S/PDIF, XP Home SP2. To use DVBViewerGE I simply copied the DVBViewerGE EXE-file into the DVBViewer program directory. Installation works fine with DVBViewerGE (V. 1.1). Playing DVD's is perfect too. To make this happen I selected both NVidia filters in the options dialogue. If I check VIEW->FILTERS, I see the list shown below: -Video Renderer -Default Direct Sound Device -NVidia Audio Decoder -Overlay Mixer -NVidia Video Decoder -DVB Source Using DVBViewer 3.0 with these settings I get no audio signal. In the property page of the audio filter I can see audio data are arriving, because the "correct" bitrate depending on the type of the audio data stream is shown. Checking VIEW->FILTERS gives the list below: -Video Renderer -Dedynamic Filter -NVidia Audio Decoder -NVidia Video Decoder -DVB Source By selecting a different filter (e.g. MPEG Audio Decoder) the audio signal is ok and the list of filters DVBViewer 3.0 also includes "Default Direct Sound Device". I'm no expert for filters but hope that this information is sufficient for a solution. Edited February 21, 2005 by kmyne Quote
Griga Posted February 21, 2005 Posted February 21, 2005 The NVidia Audio doesn't want to re-connect, once it has been connected to other filters (which I'd call a bug). It disables audio playback, if an app tries to insert additional filters after already having built the filter graph. This applies to the Dedynamic Filter (see your list, try to disable it in the options) and probably another filter ("Audio Callback", file DVBViewer\Filters\RLDumper.ax, not visible in the list, used for displaying visual designs). Quote
kmyne Posted February 21, 2005 Author Posted February 21, 2005 Perfect! The problem was "RLDumper.ax". I deregistered this filter and now the NVidia audio filter works fine. Many thanks! kmyne P.S.: By the way, why did it work with DVBViewerGE ? Quote
Griga Posted February 21, 2005 Posted February 21, 2005 The GE doesn't need a dumper filter, since it doesn't provide visual designs (those nice graphics changing with the rhythm of the music). However, the Audiorecorder Plugin won't work after unregistering RLDumper.ax. It requires a dumper filter for grabbing the audio data from the filter graph. Furthermore, if you "fall back" to DVBViewer 2.3 beta or 2.2 (for whatever reason), recording won't work without it. That's why I prefer other audio decoders, like Moonlight Odio or AC3 Filter 1.01 (both are good - and free). Quote
kmyne Posted February 21, 2005 Author Posted February 21, 2005 Thanks for the explanation, it definitely gives a better understanding of the inner workings of DVBViewer. Regarding the different filters I'm using the NVidia filters simply because I'm happy with the quality and speed in DVD mode (and this also works fine now with DVBViewer!). I removed AC3filter to reduce the number of different configurations and to avoid redundancies. Quote
spAik Posted February 28, 2005 Posted February 28, 2005 THX! now i know why nvidia didnt work with dvbv. 3. THX :DDD Quote
pietro Posted March 6, 2005 Posted March 6, 2005 Bingo !!! Now it works perfectly with nvidia ! Thanks for the hint ! regards pietro Quote
pajonk Posted June 5, 2005 Posted June 5, 2005 Sorry my stupid question. But i want to use nvidia audio decoder too. How to unregister rldumper.ax? Are there any funtionslimitations after deregisteruíng this file. using DVBV 3.1. THX Quote
Griga Posted June 5, 2005 Posted June 5, 2005 How to unregister rldumper.ax? Download the Radlight Filter Manager from the Service Center Are there any funtionslimitations after deregisteruíng this file.using DVBV 3.1. Read this thread Quote
pak Posted July 3, 2005 Posted July 3, 2005 How to unregister rldumper.ax? Download the Radlight Filter Manager from the Service Center Are there any funtionslimitations after deregisteruíng this file.using DVBV 3.1. Read this thread <{POST_SNAPBACK}> hello firend i heave a problum in skystar2PC how i can add a new channel in my list with out vidio and autio pid no i have only Frq/ and Syb rate pleas solve my problam tank's Quote
Klausing Posted July 8, 2005 Posted July 8, 2005 here is DVBViewer board not TechniSat Board ! DVBViewer dont need any TechniSat application. If you dont have all needed things to add a channel in DVBViewer, make a channel scan on this freq. Quote
