Creating SVCD from PVA-stream
Klausing
This i a translation of the very good description from plubsi. I hope my translation is good enough. (is for all people who cant speak german)
How can i produce a SVCD from a film received in PVA
In this workshop we would not have the very best qualitiy. But we want to make with justifiable eypenditure a good qualitiy SVCD.
Important ist that we observe the SVCD - standard, so we can play this film with mostly DVD players.
Following free tools we need:
( You can use Tmpgenc ore Cinema Craft Encoder, but the last one is faster. The problem is, that you have a little logo in the film after encoding)
Existing a Stream picked up with DVBViewer in the PVA-Modus. Who has a Fat32 of formatted harddisk ( has should <2Giga frontiers guarding,) because he could get some problems.
Further recommendation ,who has 2 or more hard disks : the too encodierenden Pvastream on the one Festplatte,abspeichern on the other Festplatte.Raidsystem, not to despise of course either, is.
Otherwise, processor performance is the main factor to be reduced about the required time.
Tools required:
http://gknot.doom9.org/D2S110B1.zip (DVD2SVCD)
http://gknot.doom9.org/D2S110B1c.zip (DVD2SVCD update)
http://www.tmpgenc.net/files/TMPGEnc-2.59.... .47.155-Free.zip (TMPGenc)
http://www.doom9.org/Soft21/Encoders/MPEG2.... G2/cspte250.exe demo (CinemaCraft2.5Demo)
http://www.offeryn.de/dv.htm (Pvastrumento)
http://www.tirtanium.de/extra.html, (PVA Cut),
http://home.t-online.de/home/michael-ring / (DVD2AVI_PVAView)
http://www.schnerbel.de/index.php?action=d... etailKat_id=138 (2lame)
http://www.schnerbel.de/index.php?action=d... etailKat_id=154, (Beesweet incl. Gui),
Removes the commercials:
, Start, DVD2AVI_PVAView and PVA-CUT.
Click on New Source PVA and the recordeten Pva-File loads.
In the upper window,you can see2 mpeg2 packets ,and than appear the affiliated picture in the small window of DVD2AVI_PVAView.
marking with the left mouse button the first picture of the film ,than run beams moves on until the last picture before the first commercial starts, here with the right mouse button marks the end.
Now click on ADD (uppers of the bottom run windows).
pull the upper run beam until the first picture after the commercial ,click again with left mouse button to marks, moves on until mouse button right to the last picture before the next commercial starts and marks.
Click on ADD.
The total until the end repeats.
Now clicks on SAVE AS and the advertising-free Stream stores.
Total expenditure inclusiv loads and stores about film of about 90-minutes 15-minutes with me.
closing PVA-CUT (DVD2AVI_PVAView closes automatically to).
Cuts or adden from fractions:
load the first PVA stream. and marks and adds like the description above, than load second PVA stream and make it again. load & add& load & add ...
To the end SAVE AS. and ready.
Cuts after same scheme.
Save the soundtrack and information over the video
stats PVAStrumento :
with input load the advertising-free PVAfile.
Click on INFO also shows us the data of the Filmes, mostly right also stands : Audio starts of xxx ms early. Ignores.
If you want to save the soundtrack click on DEMUX, in the newe window delete the little hook at extract video and click on START.
. Close PVAStrumento (remaining time about 5-minutes),
The separated soundtrack makes changing into miscellaneous extra qualities possible.
, To start, of DVD2SVCD:
Now, it is called unique furnishing: , if possibly always now picks physically different hard disk as storage place,
bbMPEG - path fixes
CDImage - Folder fix
Finalize -
Misc. left below DVB(pva, marks
Conversion -
About -
Log -
PVA - the path to \ cPVAS.exe fixes
DVD2AVI, save Procect in, Folder fix .
below left, I use him/it as Contrast
Assess 3 and Brightness the value 5
AUDIO - save in Folder,the storage place
Outputmode Stereo,or Joint stereo, Audio1Bitrate 192, under128 its to bad ,
.But to highly soundqualtity the videostram lost qualitiy,
Whoever wants can thesaved soundtrack after preparation remuxing.
Audiodownsample mark.
FRAMESERVER -
BITRATE -
ENCODERS - CinemaCraftEncoder, multi passport VBR, marks Assess on 3 alters.
Locate too cinemacraft\cctsp.exe fixes, Storage place fixes.
Locate to TMPGEnctmpg\TMPGEnc.exe, Storage place fixes.
put Motion Search Precision on HighQuality
Rate Control on 2-pass variable Bitrate (VBR).
MATRIX -
PULLDOWN -
We only make these attitudes unique.
Now we make the SVCD :rolleyes:
start DVD2SVCD:
Click on Conversion and loads the PVA-file
Click on encoders and either CCE or TMPGEnc selects
Click on CDImager and fixes below left whether you want images (.bin; .cue)
Click on Conversion of possibly hook with AutoShutdown and now with GO and following confirmation the Encodieren starts.
Time of a 90-minutes film with CCE 6.5 hours,TMPGEnc need the double time with the same quality .Faster CPU need less time !!!
The ready images can wright with CDRWin,CDMate or Nero (Cuesheet loads).
I i have films with a lot of action , I would change the minutes under Bitrate.
Example Mortal Kombat:
with 700er CD instead of Between 50 and 76, better 40 and 50,-second CD in accordance with.
So thats plubsis description. I hope my translation is comprehensibly ;) and helps some people
Great Klausing,thks,hope Christian will pinned it too.
Attention : next days i will bring some updates,but i post the Info here for your translation :rolleyes:
Greetings Plubsi
